New vp44 no boost still
- Replies 17
- Views 5.1k
Raffron 6 posts
dripley 5 posts
Mopar1973Man 2 posts
trreed 2 posts
Popular Days
I've seen it where the buttefly valve in there is either closed or partially closed, and causes this exact scenario. But that map sensor code could point to a false reading and that's messing wit
How about some more info on your truck. Go to your profile and fill in your signature with your truck info. It will appear on every post you make and help with diagnosing issues. By all means if you h
I know in my instance I believe the problem lies in the sensor ground splice buried in the engine wiring harness, though it could be both. I was able to stop the 237 code and then eventually stop the
Just replaced vp44 because I install quadzilla adrenaline and 2 days later I started truck and no power. Truck wouldn't make more than 5 psi boost. Everyone said it was vp44. But now truck is still the same. I was making 25psi without tuner. I have newer map sensor and I reset apps. Please help...... I am well versed with a voltage meter.
