Same old nv4500 problems
- Replies 8
- Views 1.9k
Trich27 3 posts
Mopar1973Man 2 posts
Dieselfuture 2 posts
dripley 1 post
Had the 5th gear retainer nut installed by my local shop about 6 months ago and now 5th is hung in gear. Just returned from that shop and was told they can't see any problem from shifter section on top of the tranny so it must be internal. He told me he shouldn't have to pull the tranny since 5th is in the tail section, that just means a little less in labor. This 5th gear is starting to $500 here $500 there me to death. He hasn't pulled the tail section off to see what exactly the problem is but I am sure it want be anything to do with the retainer nut because that is what he put in and said I would never have the issue again. So far he is correct I haven't loss 5th but now that is all I have is 5th. Transmissions are one of the things I don't know much about but this is causing me to educate myself. This 5th gear has been a problem for years in this tranny, so this mechanic should have a good idea on the fix. I want to go back in Monday and let him know what I want fixed since he has had the truck 2 weeks and is still in the diagnosing phase. What do I do now???????????
