ScanGuage 2
Mike, I was wondering about the Scangauge. Is it a simple plug and play setup? I am interested in getting on.Al
  • Replies 34
  • Views 10k
Would you know the dementions of the unit? I have two cubby holes in the dash and if it would fit in one of them then that's where I would like to mount it. I would drill a hole in the back of the cubby hole and run the cord through there. Also, how long a cord do they send with it? I know you can order a six foot cord but I don't think I would need that much.
Here you go the dimensions of the ScanGaugeII http://www.scangauge.com/products/sg2photos/index.shtml
I went to the dealer today and asked if there would be any issues as far as warrenty if I installed the ScanGuage. I showed him info on it that I has printed out. He said as long as it isn't a programmer then I should be ok.
  • 8 months later...
not to hi-jack but I've been emailing Scanguage for the past 2years about when they are going to have the codes for the X-gauge for Dodge. When I bought it they said 2-3months and they'll have the codes I emailed them 4-5 times since with the same response now there not even replying to my emails. Have you inquired about the X-Gauges MoparMan?
As a matter of fact I was asking if they could come up with a corrected XGauge for the MAP sensor so we can see corrected values... But my emails are slow to get responses... I'm going to try calling them soon... Here is the contact info on them... http://mopar.mopar1973man.com/cummins/manufacture/manufacture.htm
the person that use to email me back was Ron DeLong I have his email if you want it, maybe anybody that has a ScanguageII can email him about the X-Guages and why they dont have them for Dodge Diesels :thumbsup
  • 2 months later...
so did you ever get anymore info? i tried again and nothing i'm debating returning it as they said that they would have the X-Gauges for Dodge in a year but its been 2yrs ...
  • 9 months later...
I kind of wonder how much more there is that a Dodge has sensors for really? The only thing I not seen yet is fuel level sensor... Everything else is displayed already really... The only thing I upset with is MAP...
  • 4 weeks later...
I hear you on the MAP sensor. I still have some in stock at the group buy price. Can't seem to find my old thread where they were $149.95, but I have 6 left. Its a nice gauge display and code reader.
  • 3 weeks later...
Couple of questions, Are you able to get the Runtime to work? Also are you using Diesel b for fuel type?
Would something like this work if i have a edge drag and a smarty? With the 2 computers, my truck is being lied to more than 5 politicians in on a election year .:lol:
Yes... Because what matters is the GPH (flow rate) and MPH (speed) to make MPG numbers... Edge Drag is tapped like my Edge Comp and everyone thing of just because it tapped that the ECM can't see the signal... This is untrue... The ECM can see the change in signal but can't alter it. So the Edge pushes the fuel pulse forward in time and extends the pulse length. But the ECM still seeing this so it not being lied to really... It being pushed beyond it normal limits.
i believe smarty alters the ECU's fueling,timing,and boost maps...but its still the ECU sees the info
if i understand bluechip's redline correctly, the ECU and FPCM can see whats happening...just powerless to change the data
Correct... The Addon box or programmer alters the data and forces the new values apond the system but the ECM and VP44 are "powerless to change the data"...
So in this light the SG II will work just fine because the fueling data and speed data can be calibrated too. Where the stock "Overhead Idiot" is fixed for stock tires, stock gearing, stock fueling, etc... So if you modify any of these things then the overhead idiot fails to report accurate data... Where the SG II can be re-calibrated to the new data...
It sounds like a fun little tool.I will look into getting one.
I have a SGII and get very good mpg. But I have never used the gauge's display of instant mpg. You KNOW what it takes to get good mpg, and you train yourself in those driving habits, situation by situation. Just use the minimum throttle and rpms to get you where you are going. Looking at a gauge will not do it.
