- Replies 17
- Views 2.8k
Raffron 9 posts
Mopar1973Man 4 posts
trreed 3 posts
Me78569 1 post
Popular Days
I would have to say the MAP sensor or wiring is goofy. Mine is off by a little bit 1-2 PSI but not 8 PSI. Mine tend to vary about the 25 PSI mark and starts to separate where the gauge is higher than
My thought was that you may be running the wrong box on the truck, i.e. an ADR1000 box on an 01 or 02 truck, and the jumper was missing from inside, throwing off your boost reading, but your year and
My truck runs smooth and clean in the anti torque tune from the repository. My question is this.
Why does my quadzilla shows 12psi when my mechanical gauge shows 20+?
And could this be why the only tune that acts right is the anti torque tune ?
Just replaced map sensor. Not a cummins sensor.
