- Replies 12
- Views 2.8k
Towrigdually 5 posts
Mopar1973Man 2 posts
Chris O. 2 posts
Alexio Auditore 2 posts
I know the classic abs/brake lights, one of the many curses for these truck but here we go.
replaced both front sensors, replaced the sensor in the rear diff, checked all the wiring, checked the switch for the e-brake, brake fluid is good, all calipers work as they should.
Recently came into a good scanner that could read ABS codes and hooked it up, it'll read engine no problem but not abs. Is it possible that the abs module is mad and not allowing the scanner to read and that's why the lights are on?
(I also thought maybe it doesn't work but I read the codes on the jeep and the other ram, found out those issues so I know it works.)
