- Replies 8
- Views 3.5k
Christolher 4 posts
Me78569 3 posts
Mopar1973Man 1 post
Here is the tune I am running...
POWER LEVEL 15
RPM LIMIT 3700
MAX VALET MODE POWER 15%
MAXIMUM FUEL STRETCH 2200
TPS PUMP MAX 100%
TPS PUMP MIN 0%
MIN PUMP TAP FUELING % 50%
PUMP LOW BOOST SCALE 20PSI
BOOST SCALING 20PSI
MAX LOAD TIMING OFFSET 2.0°
LOW PSI TIMING REDUCT 3.0°
TIMING REDUCT SCALING 0%
LIGHT THROTTLE TIMING ADV 5.0°
LIGHT THROTTLE LOAD LIMIT(PRESET)30%
RPM TIMING MAX 13.0°-16.0°-22.0°-24.0°-28.0
(0PSI 100)(1PSI 102)-(30PSI 146) increaseing by 2 from 0PSI TO 30PSI.
iQuad-2018-04-28-08.06.02.csv
