- Replies 12
- Views 5.4k
jerricuda 5 posts
Mopar1973Man 4 posts
Dieselfuture 2 posts
dripley 1 post
Thanks for the input and info. Sometimes it pays to stop regroup and start over. I was letting crazy side effects cloud simplicity. Walked up started to trace grounds and the first one I checked was t
Is your pillar gauge mechanical or electric? Just went thru something very similar with a 237 code. Mine is in the wiring and a new MAP did not fix the problem. This could either way.
I have a 1998 3500 4X4 dually 24 valve fresh rebuild (3k miles) Industrial injection Hot Rod 44, Hamilton springs, 120 BD sticks, Air dog 150, Quadzilla , 5" exh. , Packbrake, DNE2 OD, NV4500, SB DD clutch, S&B intake & filter. Just installed Custom Airwerks turbo close to Silver Bullet in specs. Loaded trailer went from Boise to Portland and back and towed great. Only issue I had was too much black smoke for my liking at low end. by the time i got back the smoke was getting worse. Went through my injectors but no change ( easy to make all traffic vanish in my rear view mirror with pretty light to medium throttle . Decided that maybe turbo seals were leaking as adjusting tuner doesnt seem to do anything. Put stock turbo back on until I could get the new seal kit installed, which I did Monday after work. When I tried to start the truck I didnt hear the fuel pump cycle so I went to check my work and noticed that I had pulled the Negitive wires from the Batt. terminal Pass. side. Reinstalled cleaned tightened all terminals. No fuel pump no gauges no screen on my Quadzilla. (pv2) Pump is good Did the odometer check with key and got 900 920 921 940 950 999 codes, let it gauge test and all gauges moved through proper ranges. All dummy lights come on and she cranks. There is one odd thing I noticed. when the key is off the WTS light comes on faintly . turn ign. on and light goes out. I can make the light clear by removing battery cables or ECM plug. Turn ignition switch on light will return until power is removed again. Maybe PCM or injection pump? I dont think it is the ECM, but I put my spare ECM on and with key pump comes on but will not stop until power is removed and WTS light and no gauges still th same. I hate these wtf just happened issues.
