S475 vs s472 Compounds
- Replies 15
- Views 13.4k
Soooooooo not all "s472s" are created equal. Exducer sizes and other features in the compressor will make a difference. Unless you plan on running a t4 primary (do not recommend) there is
So i have a chance to pick up a s475 for a great price which may allow me to run compounds sooner than i thought. If i stick with the stock hx35 would the s475 be a good match or am i going to wish i went with something smaller?
Anyway studs and injectors are getting installed this week but i have some turbo decisions to make.
Option 1: Stick with the original plan and buy a s362 for now and compounds later down the road. ( if i go this route i would probably run a s472 as the larger turbo.)
Option 2: Pick up the s475 and run it under the hx35 right away.
Also does anyone know if the egt probe that comes with the Quadzilla is the same as the comes with the Isspro ev2 gauges? I have been having consistently low readings so i swapped them around and now the quad is reading low. Im thinking its just a bad probe and hopefully not the gauge.
Thanks for all the help guys, yall have been a great help so far.
