- Replies 17
- Views 3.8k
Standard Cab01 7 posts
Mopar1973Man 5 posts
dripley 3 posts
trreed 2 posts
Popular Days
Depends on how technical a guy wants to get about it. In our instance, saying they're synonymous is inaccurate because our trucks don't have a throttle body, so we need a true accelerator pedal positi
Yeah and no. TPS is just a 3 pin sensor. APPS is a 6 pin sensor with idle validation switch. Things are handled a bit different from just a TPS.
Use a different code reader you can't have P1693 code without a second error code. If your using the key trick typically the 2001 only reports the PCM only. Hence why you are seeing only a P1693 code.
So this is what is going on 2001 banks exhaust, hi ram,Quadzilla xzt, RV 275 injectors brand new Bosch, fass 95 big line,.
Had code1693 never found out what it was it was getting a little slow to start sometime had dead pedal sometimes and stalled sometimes. Replaced vp44 industrial injection so.
Starts great but seems to idle a little rough little. Today I had dead pedal. Oh and 1693 code is gone now fuel pressure is always 17,18.
Seems a little down on power would it still run if I jumped a tooth on the new vp?
