Oil Temp gauge installed
- Replies 20
- Views 8.6k
AH64ID 9 posts
Mopar1973Man 6 posts
dripley 1 post
Dynamic 1 post
So I've had the gauge in for about 6 months and lots of towing. In the summer on a 100° day, pulling a long grade the oil will get up to 235° when the coolant is 209-210°, that's at anywh
The oil in my Ford runs between 10-12 degrees hotter than the coolant, pretty much no matter what I'm doing with the truck, so I think you're in the ballpark. I set all of my oil temp warnings (my 6.4
I finally got around to installing my oil temp gauge.
The sender is in the filter head.
So far I don’t have many miles on it but the oil temp stays about 10° below coolant while the engine is warming and then under normal loads it’s matches coolant. I’ll be towing with it soon enough thou.
I have the ISSPRO attribute programmer but I haven’t decided what temp to set the alarm light to. I was thinking 250° thou.
Edited by AH64ID
