Thanks everyone
Just wanted to say thanks to everyone over the last few months for all the help...finally got the rig where i think it should be
I got the 63/68/12 /s475 setup dialed...ditched the smarty for a new comp box hot unlock...tapped the vp44 with a stealth cover...ditched the dap 7x.09 for some dfi 7x12's (idle is amazing and egt is 200° lower not sure how its possible lol)...valve springs,manton pushrods,headstuds...its cost me a small fortune but im now almost done minus the shock tower deletes and steed speed,thanks again to everyone that helped along the way...you guys rock
  • Replies 25
  • Views 5.3k
  • less duration needed for the same power = overall better running truck.
  • Nope not at all...the retainers and keepers slid off the valves like butter when the springs started to compress. I would imagine the valves would push down on the Piston if they were stuck but it was
I agree with @Me78569
I wouldn't sweat it.
Both sets of injectors I had from Chris were great. Idle just purred.
The 100's I had were a ridiculously clean 400hp setup. I mean crazy clean.
Driving smart with the 6x.013's were clean also once the motor was up to temp considering the setup I had.
Next injectors will be from him whatever that step will be. Plus being able to shave in shine of the injector bodies is cool too. :thumb1:
Key to large injectors.  Mine haze horribly when cold but are very tolerable when warm. 305 bar too.
They definitely purr... I had it on the road for an hour today for the commute and the thing just runs nasty I can't even believe the difference those injectors made over my old dap's...she fuels hard and spools almost instantly...im still shocked i lost almost 200° egts and i went way bigger
I'm glad I am not the only one who felt they have a pulling truck waiting in line until the thermostat opened. :lol:
