Manual Boost Controller
Hi folks it’s been a while since I posted! Life has been busy! So I received my boost controller yesterday from eBay and I’m curious if there is gains without having a Qaudzilla? Of course I hope to get a Qaud before long but I’m curious if I could use it to build more boost without tuning? I do have a boost fooler.
  • Replies 7
  • Views 2.3k
You sure could. Not sure how much a stock engine is capable of myself.
As far as boost?
HX35= 35 psi
HY35= 32 psi
5 minutes ago, Marcus2000monster said:
As far as boost?
HX35= 35 psi
HY35= 32 psi
Oops my bad I looked back over and realized what I said didn’t match your question.
Stock engine timing map is fairly retarded. Stock motor can handle more pressure than the HX can provide.
Edited by trreed
No gains without a boost fooler. After 19 psi it will start to defuel by 25 psi it will set p0234 code.
Best to get a Quadzilla.
He did say he had one. Didn't ask what it was though.
Edited by dripley
Oops my bad... :duh:
Not reading the whole post are you?? :) I have a qaudzilla boost fooler.
