DTT Pan Off Kit
Hey guys for the first time since ive owned my Dodge im flushing the trans fluid, filter change, and adding a ATS deep pan, while in there a good friend of mine mentioned a small upgrade kit that we found called the DTT Pan Off Upgrade Kit part number DTTPOSTG2960347VR. Was curious if anybody has any intel on if it helps or is worth it or should I just install a Shift kit
  • Replies 12
  • Views 5k
  • DTT uses a TCS servo, accumulator piston, strut and anchor...same as I (and many others) do. I have not had good experiences with their voltage regulator, and there are far better ways to deal with th
  • My website is www.dynamictransparts.com.   If I were going in there, I would replace the servo, accumulator piston, strut and anchor, like you referred to, as well as the pan itself. I would
I’ve never heard of it before. Not a huge fan of shift kits as they seem to leave a lot to be desired. Probably better off saving up a few more pennies and getting a full valve body.
I 100% agree!
Idk if you guys looked at the kit but for $465 it comes with
  • DTT Billet Servo
  • DTT Billet Accumulator
  • DTT Valve Body Calibration Kit
  • DTT Voltage Regulator
  • DTT Billet Band Strut
  • DTT Billet Band Anchor
also at replacing the governor soloniod while in there.
DTT uses a TCS servo, accumulator piston, strut and anchor...same as I (and many others) do. I have not had good experiences with their voltage regulator, and there are far better ways to deal with the excessive governor pressure code that can set in the 24 valve 2nd Gen trucks when raising line pressure. Just my opinion...
Also my opinion: a custom valve body gives you the best of all worlds. You don't have to make compromises like you do with a "shift kit" or "recalibration kit" of some kind. I can see a few compromises that would have to be made with the components shown in their picture.
@Dynamic do you have a website or a kit that you would reccomend? I have no real trans issues I’m just replacing fluids and filter so figured while in there help it out a little bit. I’m not pushing a ton of power but definitely more than stock.
If I were going in there, I would replace the servo, accumulator piston, strut and anchor, like you referred to, as well as the pan itself. I would also install a Borg Warner HD governor solenoid and a new transducer as preventative maintenance of sorts. If you aren't up for a full custom valve body, which would be my recommendation for best performance and functionality, I would install a Superior Shift Correction Kit, with a few specific deviations from their instructions. This would definitely be my second choice, but the Superior kit is far better than the Transgo in the 4-speed Dodges.
alright, all that can be done with removing the transmission pan during fluid and filter change?
Yes, pulling the pan and valve body. The Superior kit would involve disassembling the valve body.
After watching this part done by @Dynamic it's not to bad doing the valve body. Just time and standard tools.
@Dynamic so either the superior shift correction kit, or replace those individual parts you mentioned? Which would be better longevity wise and won’t hurt the pocket book to badly. I’m mechanically inclined and my brother in law is a ford certified mechanic so we should be able to figure most of it out.
@Dynamic I ordered the superior shift kit, and I found all the parts you listed on your website and plan to order on my payday, is there a pan you recommend or a pan I should stay away from? I don’t tow to often maybe 3-4 times a year will I tow my 5th wheel other than that i pull a small box trailer around with dirt bikes.
You'll need the Superior kit and also the other parts I listed.
Just get any decent quality aluminum pan. Mag-Hytek is a very good pan, but spendy. B&M actually makes a pretty nice pan that I've used a fair bit, and won't break the bank. You can order those from Summit racing. Just stay away from the Derale steel pans. Not a good product, in my opinion...
Even if you only tow once a year, you need to build the transmission for the task...
