balljoint time again.
this is for the 08.
so it's a toss up between EMF and Dynatrac. i have the dyna's in the 04, and they are in great shape only 25K but still.
both are giving awesome reviews online. anyone here have any thoughts on them?
  • Replies 12
  • Views 5.6k
    Has to be something about those AAM axles. Hmmm...  Still can't see buying $700 worth of ball joints.
  • Killer223
    Killer223
    dynatracs ordered. will report how the install goes.
those are second gen ball joints. i think the 3'rd gens are different with the AAM axles.
are you talking about the "professional" AC delco ones?
The 01 and 02 ball joints are strange animals with there alignment. 150k or better is pretty darn good. The 3rd gen are different but if the AC delcos will last that long in an 01 and 02 that is pretty good statement on there quality from what I know.
Matter of fact I don't think Dynatrac and some other of the HD ball joint co's even make a ball joint for an 01 or 02 4x4 and maybe 00. I have MOOG in mine with 200k on them. The have some wear and I will be due soon on replacing them.
Edited by dripley
Looking at the Dynatrac those things are crazy high price. That is just the ball joint alone. For that kind of money I can buy the entire axle for less from a wrecking yard...
https://www.dynatrac.com/rebuildable-ball-joints/balljoints/hd-balljoints-for-2003-2012-dodge-ram-2500-and-3500-4x4.html
Way different story...
https://www.rockauto.com/en/catalog/dodge,2008,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1441433,suspension,ball+joint,10070
Dynatrac's are what I run and they have 50K and doing great so far.
Cheap 3rd gen ball joints usually last thousands of miles, not tens of thousands of miles.
After several BJ replacements the axle gets worn and you need a new axle...
Has to be something about those AAM axles. Hmmm... :think: Still can't see buying $700 worth of ball joints. :broke:
MOOG is cheap junk on a 3rd gen. They barely last 50K miles on gas trucks, let alone these heavy Cummins.
Not sure why they work well for 2nd and not for 3rd.... could be the weight.
LOL... MOOG is no longer USA made. It all foreign country produced. It's junk for the 2nd Gens. I won't buy MOOG either.  :wink:
About a year after I installed I started hearing all kinds of bad things about the MOOG products. Enough that I probably won't use them next time. But I do have 200k on them now and cant complain. Just relating experience.
anyone know about the EMF? the idea looks promising. but i'd like to hear from someone that has 100+K on a set.
