- Replies 28
- Views 6k
Silverdodge 10 posts
trreed 9 posts
Dieselfuture 5 posts
dripley 2 posts
@dripley I only got like 4 or so... 2 to watch driving is almost too much to ask!
Well they were in there the carrier had abnormal wear from heat I guess they said some one set the gears up previously and ya well she's getting a true trac and fully done pumpkin wise but ya ugh neve
I replaced my ring and pinion due to a tiny chip in the ring gear (from shredded spider gears). A whole tooth missing like that is asking for trouble down the road, since helical gears distribute the
I put a used d80 in my cummins a month or so ago and I just filled the fluid everything turned ok so I said whatever well pulling a trailer back 300 miles yesterday I lost the abs speed sensor no mph abs brake light on blah sp I go get another sensor thinking that was shot pulled it out and half of it was missing well long story short everything meshes and is quiet so I'm going to run it just weird
