I need help spending some money
- Replies 25
- Views 4.6k
JAG1 7 posts
SilverMoose 7 posts
dripley 5 posts
Mopar1973Man 3 posts
While you’re in there you might consider changing tappet cover gasket
I have to apologize about the overflow valve question. That was a big brain on my side. I completely forgot about the banjo bolt there for the return. Anyway, Things went real well and
Its a good feeling to get that done and go so well. Part of the reason it's important to learn is all the talk about the VP being the weak point with these trucks. Using 2 stroke in the fuel, with goo
So I'm pulling the trigger on ordering a VP44. I got dead pedal 3 times yesterday and have had enough of that. I'm planning on getting it from DAP. Does anyone have any pluses or minuses about this or any other suggestions?
I figured this would happen as my brother's ignorance with the VP44 is probably what lead to its premature death. With 2 stock lift pumps in it with no TCW3 and more than likely constant low pressure sound like a death sentence. He also used if for towing 2 to 3 horses and very little non towing. The silvermoose had a very demanding first 60k miles.
This is going to be one expensive week. My tires will be getting replaced as well. They currently have over 50k on them and there is still a good amount of tread left but they are dated 2014 and are not behaving nicely.
Thank and appreciate any input.
L8tr
D
