Dual Disk Upgrade clutch fork question
- Replies 6
- Views 2k
Mopar1973Man 2 posts
KATOOM 2 posts
dripley 1 post
JDHudsn 1 post
Popular Days
Use what Southbend told you to use. If they supplied a new part then they must deem that part necessary because I didnt get a new fork in my single disc clutch kit. If you're still concerned, call t
I would second that. There is a reason they included it. What little I have read about the dual disk clutches says they need a different clutch fork.
If the problem with quality control is lower strength and/or function then thats an issue I would definitely have a problem with. But if your concern is aesthetical then sorry but no one is going to
Hey guys I am doing the south bend dual dish 3250-5K-ORG with the 1-3/8” input shaft upgrade as well as the 5th gear retaining nut upgrade. I am all the way to the clutch for and the throw out bearing step. I read the directions and it said to replace the clutch fork with the one supplied in the kit. However it is poor quality compared to the OEM one.
Will I have issues if I do not use the south bend one?
I’m looking for an education on this because to me these parts look very similar.
