'02 2500 turns over but won't start
- Replies 21
- Views 4.5k
TommyGSr 7 posts
Mopar1973Man 6 posts
dripley 5 posts
KATOOM 2 posts
Popular Days
You need to replace the batteries together. The old weaker battery will drag the new one down.
Good chance you need to reprime the fuel system. That would be the first thing I would try. Could have lost prime sitting there and opening and draining the fuel canister and changing the fuel filterw
Cranking the engine. The fuel pump relay in the PDC is the only control for the VP44. If that relay is bad or failed it will toss a P1689 code.
I have a 2002 Dodge 2500 w/ approx 135000 mi. the injection pump was replaced by a dealer when the truck had 98000 mi. The truck sat idle for about three weeks and when I went to start it the batts were very weak, turned over twice and went dead. I charged the batts, cleaned the terminals, but the engine would just spin. The lift pump is working, and there is fuel in the tank. I also changed the fuel filter and drained the water separator. Still, no start! Help!!!
