dyno numbers
just a quick question. has anyone seen or had dyno numbers with and without running an air filter. THIS IS FOR DYNO/TRACK PURPOSES ONLY!!!! i dont wanna hear how its stupid to drive around without a filter. almost everyone i see takes their filter off or always runs no filter on their setup for dyno/track runs
  • Replies 45
  • Views 10.2k
  • I dont have the dyno numbers you're after since I've never seen anyone do a run with and without air filter.  But nonetheless, I really cant imagine what benefit you'd get since most BHAF's are rated
    I can see for track or dyno purposes of putting on a velocity stack. Then when you are done with the fun I would toss the BHAF back on again.
  • You might see a small gain.  There is only few percent difference in flow acceleration versus a pipe with a slight radius (stock, BHAF, etc) and a smooth radius.  A longer stack will net more gains th
27 minutes ago, Dieselfuture said:
You can be first :thumb1:
Not being a smart:moon: just maybe everyone thinks that that's how it's been done for ever and just take their k&n off and see an increase :lmao:
Makes you wonder why they still use k&n :think:
im going to i think. 2 weeks until MDS diesel showdown.
25 minutes ago, AH64ID said:
I would research the BHAF you want to run and see what it's specs are. You might have to do a little shopping thou.
Most people don't care what their numbers are without a filter as most wouldn't ever run without a filter.
donaldson b105006 is the one ive read is pretty good. pretty sure it was recommended by moparman on a thread several years ago. unless there is one that new and exciting.
it says rated flow Lr:450cfm
rated flow Mr:590 cfm
those seem awfully low dont they? What is Mr and Lr
Edited by cumminsVP2001
I don't see that part number on Donaldsons website, but yes that seems like too little flow for a larger turbo. It's likely great for a stock turbo.
LR, MR, and HR are low, medium, and high restriction... which basically means how much vacuum they produce at said flow.
do you happen to have a part number for a high flowing one? this is the one i had pulled up https://www.amazon.com/Donaldson-kfB105006-B105006-Filter/dp/B00JYL2CF2
https://catalog.donaldson.com/productDetail/en/A/B125003?productId=11674&skuId=s10302 this is the highest flowing one i have found and with pressure rating which i guess means everything from a few forums ive read. looks like i winner
nevermind. i dont think that would even fit looking at the dimensions.
6 minutes ago, KATOOM said:
Here's Donaldson's catalog.
Donaldson catalog.pdf
the next question is which is the best flowing but still fit a 24v
the 105006 is the best flowing but stil has a 4 inch outlet. but its only flowing 680 at its best
