Hi, I just joined. I found this site while searching for info on hooking up 4th gen pr seats in my 1st gen. I bought a set of black leather power Lariame seats at this years Mopar Nats. I just cleaned and conditioned them and they are not as straight forward as I had hoped. Anybody done this?
  • Replies 7
  • Views 1.6k
I'm assuming there are differences in the floorboard and mounting. Basically you going to have to make steel blocks for the base of the seats and the use longer bolts. I've seen people retrofit different seats into 1st gens like a friend mounted a Ford bench seat in his 92 Dodge and took a bit of block and bolt work.
The mounting is not the issue, wiring, lot's of wiring. I have a FSM and power seats are not even mentioned. I assumed a 12v supply and a neg wire and I'd be set. It looks like small processers under the seats and 8-10 wire connectors. I'm assuming again but I'm thinking everything is going to and from the PCU. I know somebody has done it, if not, I'll be the first.
Welcome. Closest i have come to what you're doing is a set of manual 2nd gen seats in a 2nd. I wont be much help.
Afterv looking them over, I think it can be done WO too much trouble. I only want pr seats. The heat feature is moot to me as it's a fair weather driver. The vent feature may get the nod though. I'm trying to run down some schematics on the wiring, that will help.
Send over the fsm if you can and we can look at the wiring diagrams and help you out.  I haven't gotten into the wiring yet.
I have the 93 FSM and pr seats are not even mentioned in the electrical forward. I'm assuming it wasn't available.
