So I put a quadzilla on my truck today and I fell like it has more power but it wont smoke at all even on level 10 so I'm not sure of its hooked up right or maybe the wire tap to the pump isnt I. All the way I have no idea
  • Replies 6
  • Views 1.7k
Default tune is rather limited.
You need to build your own tune or dive into the download area and get a tune. Either way most of our tunes don't smoke. My daily tune is defueled pretty good on the starting edge for the fuel map.
I just got the quad with the control pad ? So I dont think I can change any of the tunes
you can't.   you should ditch the pod, it is old out of date tuning.
Use a multimetere and test for 12v at the wiretap per the install directions.
Edited by Me78569
I got the v2 tuning on it I'm pretty sure I can buy the bt adaptors and switch it right? Do I check for 12v while running
you can't have v2 without the iquad.  or if you do the tune is just a generic safe tune.  You need to just swap the iquad.
I dont remember off the top of my head, read the install directions.
