AC Compressor “short cycling”
- Replies 20
- Views 6.8k
dripley 5 posts
Mj2545 5 posts
Mopar1973Man 4 posts
Royal Squire 2 posts
Popular Days
I hear that's what happens to old people.
The orifice tube is plugged. When the compressor is replaced the orifice tuber and the accumulator have to be changed. If there is black death in the system you have to flush the entire system clean.
The orifice tube is located on the low side correct? The solid line that runs between the accumulator and front condenser? I will check this afternoon. I haven’t turned on the ac besides h
Hey,
having a issue with ac components. Today i replaced the ac compressor due to a slight grinding noise within the compressor. After changing the pump, took my truck to a shop to have it vacuumed and recharged properly.
They tried to recharge the system but it did not work. The compressor and lines accepted all the nessessary R134a needed. (0.90 kg) or 32oz. The compressor started to short cycle, acting like it was low on refrigerant. Started paying attention the the low and high side gauges and immediately noticed something was wrong. Low side, started around 50-55 and drops to 20 under clutch engagement. At the same time, high side, started around 220-240 and spikes to 450+
My understanding is that the system is over pressurizing the high side.
I’m thinking of a blockage somewhere? But idk.
Since ive already replaced the compressor, also which I filled to the 8oz. oil specifications. I ordered new high and low side lines and a new accumulator. Hoping that the blockage is in the orifice tube or small screen and the other pieces for safe measure.
Any recommendations, maybe just try to replace the liquid line first? I’d like to replace as little as possible and return what I don’t need.
Thanks
