hey guys I'm looking for the best compound set up for my truck. Its a 99 24v with 125 hp injectors, headstuds, fass 150, CAI, 4 inch exhaust, iQuad V2 tunes, and a BW 364 sxe. i am curious what would be the best size turbo to use as my big turbo while using my 364 as the small turbo. Also if anybody has recommendations on piping kits that work well with these trucks. I don't plan to do any thing else power wise for the truck after this.
  • Replies 30
  • Views 10k
so what egt temps are you seeing currently?  i run rv 275 injectors, 6spd manny, 35" tires and 4.10's everything else is stock and cruising flat ground 65 6th gear mi around 700-750ish but i can peg the egt easy if i stomp on it but i defuel at 1250.
Edited by CUMMINSDIESELPWR
At 65 mph at least 1150-1200 unless it’s just coasting then lower to about the same numbers your at. But I’m geared at 3.55 with 37s
Top speed this morning on the way to work was 54MPH, 1081 EGT, 11lbs boost, and 2432 RPM. I live 7 miles away from work.
holy crap yeah you need shorter gearing with those 37’s
is yours an auto or manual?
On 8/28/2018 at 6:54 AM, Mopar1973Man said:
Simple ditch the tires or change ring and pinion gears. EGT problem goes away.
Right now with my setup I can be hitch up grossing 17k to 18k pounds put my Quadzilla on level 3 and mash my throttle to the floor with 7 x 0.0085 injectors and HX35/40 turbo and never reach 1,200*F. I'm also running 31" tires now but soon to drop to 30" tires (245/75 R16) which drops another 100*F off the EGT's and increases torque to the ground.
I said the same thing... He needs to regear the truck or ditch the 37" tires.
im getting away with running 35's as i have the 4:10 ratio, it does well. the only time i use 6th gear now is if im on level flat road cruising with no load/trailer. other than that im in 5th and it works out well
Planning to regear to 4.56 this month and then upgrade Injectors to 200HP
