- Replies 17
- Views 4.7k
Mopar1973Man 7 posts
Marcus2000monster 5 posts
dripley 2 posts
IBMobile 2 posts
Popular Days
First off I typically hook up my manifold gauge and see what the static pressure is. If there is no pressure in the system then you need to start looking for leaks. Typically I would put a shot of UV
The only thing I can add is if it is leaking in the hvac box, that is the only one you cant see.
12oz cans only with just Freon. Do not buy the quickie cans they have stop leak and oil.
Good evening folks! So for a good while now my air conditioner has not been blowing cold at all. Almost lukewarm. Most folks say it needs a Freon recharge which is available at my local parts house. My concern is that if it needs recharged to blow cold again does that not mean that it is leaking out somewhere? I would like a step by step guide to recharging and testing for leaks if y’all would be so kind. Thanks!
