2001 Cummins has HickUps Engine Quits then Runs (P1689 code solved)
- Replies 44
- Views 12.3k
int3man 25 posts
dripley 9 posts
Mopar1973Man 5 posts
Marcus2000monster 1 post
O.K. Truck is running strong. I passed Smog today. Life is good once more. For me P1689 The FUEL SYSTEM RELAY was causing the grief. My problem solved. Your mileage may va
Yes it could be as easy as that. P1689 The FUEL SYSTEM RELAY was causing the grief. I swapped it with a spare relay and have driven it for 3 trips no Hick-ups. I'll post again in a week to verify
Passed Smog and Truck is now in my name!!!! Yippie!! Thanks All Michael
So this started just after I got the truck home. I moved from one driveway to an other and the engine stopped. Restarted moved and stopped. Then ran fine. Week later and 1,000 miles into my get to know each other trip and the truck starts hick upping on the freeway going through Portland after 3 hours of driving. Did it for 7 - 8 times, not in conjunction of the bumps in the road or anything.
So we are a week later and it starts hic-cuping on the way to Ace. Engine just dies then runs again. 17 PSI on the FASS to the VP. No Water in the Water Trap. Does it for 8-10 times. Just like you bumped the switch off then on again. I've seen things about data logging the edge is still connected, does it have an data logging capacity? I'm pulling it off this weekend so that I can get it smogged next week.
Checked Codes and
P0521
P1693
P1765
P0622
Thanks Guys
Michael
Edited by int3man
Added Codes
