APPS issues
I just put a vp44 on my truck and got it running but it idles at 1000 rpm but when I floor it it’ll idle at normal rpm. With the key on I tested all 6 wires and they all have right around 5v. Unplugged the tps and it idles fine obviously but what should I be chasing at this point? Codes are p0123 p0113 p0118 p01693 x2 p0236 p0237
  • Replies 11
  • Views 2.9k
    Again pull the Edge juice off you might find a different answer. It's been known to cause issues if the boost fooler shorts out. First ditch the Edge Juice clear your codes again then see if the codes
  • Start simple. Disconnect the Edge and eliminate it and tnen work forward. Costs nothing but time.
Time to replace the APPS sensor. Make sure to get a Timbo's APPS and don't try to adjust the voltage. This could be what you've done with voltage adjustment.
The apps was replaced this winter. But why would even the grounds have 5v??
Possible the sensor ground is shorted to sensor ground? Is there any APPS wiring mods?
As for the P0123 code...
Possible Causes
5-volt Supply At APPS Shorted To Voltage (Engine Running)
APPS 5-volt Supply Circuit Shorted To Voltage
APPS Signal Circuit Shorted To Voltage (Engine Running)
APPS Return Circuit Open
APPS Signal Circuit Open From APPS To ECM
APPS 5-volt Supply Circuit Open
PCM (APPS) Circuit Shorted To Voltage With The Engine Running
PCM (APPS) Short To Voltage With Ignition Key On
APPS Open Between PCM And ECM
Open APPS Circuit
Accelerator Pedal Position Sensor (APPS)
Engine Control Module
You didn't have this problem and no codes before the VP44 was replaced?  Is this right?
If so then you have a wire problem probable in the harness near the VP.  Open the harness near the V Pand check for a bad power/ground splice or pinched wires
Ok. But all the other high volt codes make me think it’s not the sensor but the ECM itself going haywire with the 5v supply
Again pull the Edge juice off you might find a different answer. It's been known to cause issues if the boost fooler shorts out. First ditch the Edge Juice clear your codes again then see if the codes return if not the Edge Juice is damaged.
Do I need to unplug all the plugs or just disconnect it at the box
Disconnect every thing back to stock. No need to remove it just plug everything.
