- Replies 11
- Views 3.4k
Mopar1973Man 4 posts
njraymond98 4 posts
dripley 2 posts
IBMobile 1 post
Popular Days
Again pull the Edge juice off you might find a different answer. It's been known to cause issues if the boost fooler shorts out. First ditch the Edge Juice clear your codes again then see if the codes
Start simple. Disconnect the Edge and eliminate it and tnen work forward. Costs nothing but time.
I just put a vp44 on my truck and got it running but it idles at 1000 rpm but when I floor it it’ll idle at normal rpm. With the key on I tested all 6 wires and they all have right around 5v. Unplugged the tps and it idles fine obviously but what should I be chasing at this point? Codes are p0123 p0113 p0118 p01693 x2 p0236 p0237
