- Replies 36
- Views 4.4k
Ronniemx3 16 posts
Mopar1973Man 6 posts
trreed 6 posts
Dieselfuture 5 posts
I'm betting there's a misalignment yet. The way I like to do injectors is put injector in, pop in crossover tube, tighten down high pressure line (that way the injector can still rotate in its bore t
@Dieselfuture i knew you sold me them in good faith hence me never moaning or asking for refunds or asking for you to sort it etc top guy ????
If you're going to be loosening the 19mm nuts completely, it'd be better for you to pull the line to the side and pop the crossover tube out and completely pull the injector and re-seat.
Fitted my 60hp injectors today and now have a slight 'miss' at idle truck pulls hard still no issues higher in the rpm range just a vibration in the cab at idle. Any ideas??
