Morimoto M Led projector retrofit.
- Replies 11
- Views 5.6k
Me78569 7 posts
trreed 2 posts
Mopar1973Man 1 post
Royal Squire 1 post
@KATOOM I think this is what Mike wanted you to take a peek at. https://mopar1973man.com/announcement/68-morimoto-mled-projector-raffle/ Update: Af
lol nope. I like being married.
The time has come to test out the MLED setup from Morimoto, there will be a lot to follow from this Mopar1973man.com project so keep an eye out
First shots wired up to a spare battery using a spare connector. Nothing installed yet.
First thoughts. The hotspot is WOW I dont know that this would be a good setup for a car because of the foreground light that these would put out. However the truck should be high enough to not matter. The lux tests show impressive light in the hotspot compared to even the D2S 4.0 setup.
Width isn't as good as the HID setups I have seen, but it is not terrible. It is approx the same as the mini h1 setup I had, but the D2S 4.0 would be better width.
The project.
I will be doing a retrofit into the new 4th gen showing how to accomplish better lights for the Quad headlight trucks out there. The big perk of the LED projector is the ease of install when it comes to dealing with the canbus system. HID's require special things to make it work, these "should" work out of the box, that is left to be seen however. There is also less stuff to wire up and get routed. If you have seen the headlight area of the headlights in a 4th gen you will know that is a good thing.
HID vs LED
HID projector ** Note the bulb sits in the center back of the reflector for a 360* reflection of light through the lens.
LED ** note the LED shines directly up into a half moon reflector.
Look out for more to come!
