Best Way to Dry Carpet INSIDE the Truck?
Got to school yesterday and noticed my passenger side rubber floor mat looked a bit wet, so I lifted it up and loan behold my carpet was soaked. I grabbed some paper towels and soaked it up a bit while I was at school and hurried home and pulled some of the carpet up and stuck a dehumidifier in the passenger seat overnight. Just went out and checked it and it has dried the carpet but that insulation is still a bit wet. Anyone know any cool tricks to drying a carpet in a truck? Tried taking the passenger seat out but found out its spot welded to everything else and didnt feel like taking it all out because of the mess and it was late. Anything helps, thanks!
EDIT: I have 0 clue what caused it, just checked the AC drain and it wasnt clogged so I checked the weather stripping and it isnt torn up or anything, so any incite on that would be very much appreciated. Thanks again!
Edited by TheGreatWhite
  • Replies 81
  • Views 11.2k
    Hence the nickname "Chicken Man". Dave is an awesome gent I've talked to many of times and shared a beer on the phone numbers of times. One of these days we just might meet.
  • This was a bit different in that we built a new next to an old and demo'd the old one.they were supposed to close the store for 2 months for the transistion, but operator decided he did not want to do
  • Dieselfuture
    Dieselfuture
    I took my carpet out, power washed it and hung it on the fence to dry. I also ripped all the padding off of it. Then I sand blasted my floor and painted it 3 times. I also did put about a foot of hose
Would not hurt. Just set it up outside the door and leave it it open.
Ok, thank you!
When the AC spout was dribbling back into my truck and soaked the passenger floor I did just what you did and put a dehumidifier in the fron seat overnight, dried everything. Maybe another night of dehumidifier.
Thats what I was thinking. It got a lot of the water but parts of the insulation and sound deadening foam were a bit wet. Gotta paint some of my floor a bit as well since its getting a bit crusty.
Was the 90* fitting still on the HVAC drain thru the fire wall? I knocked mine off when rebuilt the box and flooded the floor. The wind just blows back in around the seal to the fire wall. I put a short piece of clear tubing on mine and no more problem.
Edited by dripley
Uhhhhh cannot confirm nor deny and to be honest i have no idea what 90* fitting you're talking about. Have any pictures or anything?
Not the best picture but if look just below the ac drier you can see the hose I put on mine. It and the drier is in the strip of sunlight and the hose runs straight back to drain outlet on the fire wall. You might see it better from underneath.20180913_145115.jpg.8a5b54dd5601569119b4ce131cac0218.jpg
The tube is still poking out of the firewall on mine and was properly draining yesterday when a buddy of mine and I went and looked. I like that setup I might have to run a hose like that! I assume the T fitting is the drain itself?
There was no tee on mine just the pipe sticking out. I thought they came with a 90 but since I knocked mine off I dont know for sure. They will drain fine like that sitting still, driving will let the wind blow it back into the cab and you get wet carpet. At least thats what mine did untill I put the hose on it.
Edited by dripley
1 minute ago, dripley said:
There was no tee on mine just the pipe sticking out. I thought they came with a 90 but since I knocked mine off I dont know for sure. They will drain like that sitting still, driving will let the wind blow it back into the cab and you get carpet. At least thats what mine did untill I put the hose on it.
Sounds like I need some hose, how long is yours?
A foot or so. Think I bought 2 feet and cut it to where i liked it. Its just clear tubing from Lowe's or whatever is near by. Nothing special. I forget the size but it is just slipped over the drain.
Alrighty, thanks man! Really appreciate the help. Aggravates the crap out of me cause I don't have a backup vehicle yet and I was supposed to go get rock with it today but its all torn apart drying because of something stupid.
I am sitting with a blown lift pump so feel your pain. Got a new one coming tomorrow..
Edited by dripley
Airdog all the way :thumbup2: PDD actually has a mechanical one coming out soon thats pretty simple and can handle up to 200psi I believe.
I took my carpet out, power washed it and hung it on the fence to dry. I also ripped all the padding off of it. Then I sand blasted my floor and painted it 3 times. I also did put about a foot of hose on that nipple outside the cab and zip-tied it to my brake line.
Edited by Dieselfuture
Phone keeps changing my spelling
15 minutes ago, Dieselfuture said:
I took my carpet out, power washed it and hung it on the fence to dry. I also raped all the padding off of it. Then I sandblasted my floor and painted it 3 times. I also did for about a foot a hose on that nipple outside the cab and zip-tied it to my brake line.
Did your front seats come out as one unit or individually? Also the padding you mentioned, is that the soundproof padding?
Mine came out separate, back seat just flips up. I think it's sound proofing stuff, it's thick and had all the moisture in it rotting away floor. I didn't notice much diference in sound, but that's just me.
I meant with the front seats and console, mine seem to be spot welded together. Did you use dry ice to get rid of the sound deadening material?
