Best Way to Dry Carpet INSIDE the Truck?
Got to school yesterday and noticed my passenger side rubber floor mat looked a bit wet, so I lifted it up and loan behold my carpet was soaked. I grabbed some paper towels and soaked it up a bit while I was at school and hurried home and pulled some of the carpet up and stuck a dehumidifier in the passenger seat overnight. Just went out and checked it and it has dried the carpet but that insulation is still a bit wet. Anyone know any cool tricks to drying a carpet in a truck? Tried taking the passenger seat out but found out its spot welded to everything else and didnt feel like taking it all out because of the mess and it was late. Anything helps, thanks!
EDIT: I have 0 clue what caused it, just checked the AC drain and it wasnt clogged so I checked the weather stripping and it isnt torn up or anything, so any incite on that would be very much appreciated. Thanks again!
Edited by TheGreatWhite
  • Replies 81
  • Views 10.5k
    Hence the nickname "Chicken Man". Dave is an awesome gent I've talked to many of times and shared a beer on the phone numbers of times. One of these days we just might meet.
  • This was a bit different in that we built a new next to an old and demo'd the old one.they were supposed to close the store for 2 months for the transistion, but operator decided he did not want to do
  • Dieselfuture
    Dieselfuture
    I took my carpet out, power washed it and hung it on the fence to dry. I also ripped all the padding off of it. Then I sand blasted my floor and painted it 3 times. I also did put about a foot of hose
The stuff we used last this summer you overlapped by 4 inches or whatever overlapped finished the work at the end. Had to make sure it had at least a 1/4'' of melted squish out at the edges or overlaps. that makes sure your getting the right temperatures and becomes fused.
Sounds sbout same, the torch part was throwing me off. No torch used on ours, just heat guns.
Ours is 39 inch wide rolls and you heat with a propane type weed burner. It can go fast laying it down, but that fast may mean mistakes too, so I like your heat gun way.
I dont think so but I guess it is possible if the drain clogged. The fan is not in the low spot like the drain is. It is about 3" higher. I had one loose on mine a few months back and never got any water in the floor.
Ok. I reached up under there and noticed that, didn't know if water got in there at any point or not. I'll keep searching. I found where the drain goes through the firewall after looking for about 5 seconds. I'll keep an eye out on it to see if its weeping water between the rubber part and the firewall.
I'm with @dripley , possible but you have bigger problems if water was coming from there. Have you put a chunk of hose on that nipple outside the firewall yet. That's where I had my problem.
I'm thinking possible crack in that hose where it connects behind the firewall. How much water did you say you got out so far ?
Somewhere around 3-5 gallons if I had to guess. I have paper towels around the drain inside the cab to check for leaks today. Pretty much got the whole truck dried out now and no water so far.
Are you running the AC? Thats when you would see it.
Ya it's on max AC to avoid it getting wet again, assuming that's the problem
AC on any setting will generate condensate. Your cab is not airtight. I can sit with mine running on max in the parking lot and still have a trail of water coming from it.
Oh ok that's good to know! I was told by my dad to keep it on there to reduce the water, but according to my paper towel I put around the drain at the firewall it isn't wet.... Soooooo I don't know where to go from there.
Recirculate will reduce it, yes. Eleminate it, no. As long as humidity gets in condensate will exist. How humid is it in Kansas? We are still at 90* and 80% out here in NC. Not to mention we will be soaking up a tropical storm for the next month. About sick of this heat.
My weather app is saying 88* at 55% humidity. You guys get hit pretty bad by the storm?
No. We were lucky. Got rain at home starting early Sunday am into Monday am and a little wind. That was in Hickory NC. The job is in Columbia SC and got about the same. The coast got hammered more with storm surge and some places got 30"+ of rain. Now they get to deal with all the inland rain that is coming to them in the rivers. So their storm is not over with yet. Suns shining and the rivers are over flowing.
Glad to hear it!
That's a lot of water, I hope you find where its coming from.
Do you have the cab marker lights?
Also is it possible you forgot and left a window down in a heavy downpour?
