New Injectors + new codes + zero throttle
- Replies 55
- Views 7.7k
leety 22 posts
Mopar1973Man 12 posts
dripley 12 posts
trreed 4 posts
Popular Days
I would clear the codes and see if they come back. Then chase them.
I upgraded from stock to Bosch RV 275
The problem is the Edge EZ fuel map is design around only the stock injector. So now that you step up ot the RV275 there is no way to remap the fuel curve versus boost to control the smoke. This why p
I installed a new set of injectors and bled the lines. It'll fire up. Running rough though.
When I hit the gas pedal I get zero.
Check engine light is on
3 key turn read offers me these clues.
PCU
P0122 + P1693
ECU
P0222 + P1693
Update got the throttle back, fixed itself, let it idol and now it seems to be running smooth.
Error codes still in play.
