Good injector combo for edge users!
- Replies 22
- Views 11.5k
Mopar1973Man 8 posts
2000Ram2500 8 posts
Me78569 2 posts
Tittle Diesel Performance 2 posts
yes
Yeah any bluetooth device with a screen. Tablet or cellphone. You can even use a Android stereo like some other people have.
So if your running a junky edge comp or juice and want just a little more fun, this is what smoke out put you can expect with a 90hp 7x.0085 VCO injector from DAP. Clean burning and sensible injector for a well balanced rig. Pop pressure on this truck is 300bar.
Truck setup: 99 model year, fass 95, edge juice (same program as comp), 4” exhaust, HX35W, garbage jasper trans, triple disc, 4.10 gear.
this specific truck doesn’t have the pump tap installed due to a new VP44 installed so this is just stock, level 1/sub 1 and level 2/sub 1 for low smoke and smooth acceleration to keep traction under control. With levels 3-4-5-6 with the pump tap of course expect smoke and hard torque and acceleration. This truck is a fleet tow rig and they don’t run the pump tap because employees drive the truck and they don’t want it hotrodded but wanted a little more pull without the pump tap being installed.
stock:
level 1/sub 1:
level 2/sub 1:
Good setup for daily drivers and tow rigs. You can hit 1300-1350* on wide open runs on all levels so make sure you have a good set of gauges (not glow shi(f)t, there garbage, slow and your gonna melt a piston)... would work well with S03 users also. Levels 1-4 or if you use REVO settings (actual level is irrelevant then).
Edited by Tittle Diesel Performance
