Change to Limited Slip
- Replies 27
- Views 4.8k
Mopar1973Man 8 posts
Greenlee 7 posts
dripley 4 posts
Marcus2000monster 4 posts
Popular Days
Secret... If you and me where to walk out into the snow we would sink every step we make. Then if you put on snowshoes you can walk on top of the snow. The secret is I've always ran small
We got that one already covered.
My 24 valve is a RWD and not a 4x4. I have one tire pulling and would like to change that to a limited slip so both would pull if needed. I have been stuck in the yard of a house we rented after heavy rains. I had a rear end changed over to limited slip by a garage that was supposed to be best. After parts and labor it was a shocking $1,200.00 and that was back in the early 90s. It went out in less than 9 months, completely shot. I wished I had done it differently. So with all of that being said should I seek out another Master Mechanic to add the parts to make it limited slip or find a rear end from a yard and go that route. Maybe as long as I stay on solid ground it will be fine. I had hopes of getting a small 5th that my wife and I could go on trips in. The 24 valve should be more than capable and even better with the new injectors added but I'm concerned about having only one wheel pulling. Any suggestions??? Thank you.
