ATF Oil Change. Service Manual Capacity Incorrect?
- Replies 11
- Views 2k
Mopar1973Man 4 posts
keithb7 3 posts
2000Ram2500 2 posts
015point9 1 post
Today I dropped the transmission pan on my 1998.5 24V Cummins 2500, automatic transmission. I read the manual first to review the task.I bought the oil amount they recommended, at 4 quarts. I reinstalled the pan and put 4 quarts back in so far. ATF is just barely reading on the low end of the dipstick.
2 different places in the manual say 2 different capacities, for the same tranny model. As seen below here.
I just dropped the pan to install a new gasket that was leaking. Looking in my drain tub, there is a lot more than 4 quarts that came out. I am headed back to the store to by more oil. Looking at the drain tub, I'd guess about 7-8 quarts drained out. Any ideas on what my tranny will have required by the time the level is right?
I am testing the level correctly as instructed in the manual. I am not too concerned about overfilling it. As I mentioned, a heck of a lot more than 4 quarts came out. Thanks.
Edited by keithb7
