- Replies 11
 - Views 1.5k
								Mopar1973Man 4 posts
								dave110 3 posts
								Dieselfuture 2 posts
								JAG1 1 post
Popular Days
I would personally get an adjustable one, things aren't going to be in same place as they were 16 years ago. Centering axle under trucks frame makes more sense to me then lifting body high enough to g
If everything is still factory height then it should be the same even 16 years later. Like my truck, no lift or leveling kit, so factory size track bar should be the same years later. The axle center
Replace the entire bar. The factory style bar is a vulcanized rubber insert that isn't designed for replacement.
Looking over my truck for annual inspection. With the wheels on the ground and a helper turning back and forth I can see the bushing moving a bit on the end where it connects to the axle. Seems to me a rubber bushing would give a bit but I've read any movement is bad.Other end has no play. Should I replace? If so what is needed to do a 3 gen bar on the truck in my sig.? Is it worth it, and what kit is available? Is kit bolt on and go or are there mods. to be made?
