2001 2500 24valve steering
- Replies 26
- Views 6.9k
ruedger455 10 posts
Mopar1973Man 6 posts
NIsaacs 6 posts
Dieselfuture 3 posts
Ok so we all know that our trucks have horrible steering slop and play. Well mine was all normal and crappy then the other day my steering wheel popped when turning out of my drive away and now my steering is so bad I cant drive. If i hit a bump it shoots my truck into the other lane and j have to turn my wheel almost 180 degrees to correct it. I noticed that the shaft at the steering box where the steering shaft bolts to is almost like its stripped out in the steering shaft. Does anyone know if the steering shaft collar or the spline on the gear box are aluminum? I should probably replace both of them but money is tight right now.
