- Replies 6
- Views 6k
dorkweed 2 posts
Smarty Support 1 post
01cummins4ever 1 post
The_Hammer 1 post
54,5xx miles on my '16 Silverado bought new. AFM has been deleted on my truck via running in M5 or by using the Range AFM delete module. In all the miles on my truck.............I'll bet less than 1
They claim that the Range AFM delete module is undetectable. I would think that if they want to dig deep they could find out how many times that AFM is active per key start ups or something like that
My wife's 2008 GMC Sierra 1500 developed a misfire on cylinder #1 which was accompanied by a strange chirping sound. I set up a dial indicator on the rockers to check the lift and sure enough the intake on cylinder #1 was about half of what it should be. This is what I found after tearing the engine down.
There were no spun bearings so the only machine work needed is to have the crank journals ground and the heads resurfaced. I am deleting the AFM/DOD garbage from this engine. I already have a new non-afm cam, lifters, lifter trays, valley plate, various bolts and gaskets, and the ECM has been flashed with the correct factory tune so I won't have any dtc codes to deal with. The pistons and rods are still fine so I'm just going to replace the rings and lightly hone the cylinders. There is no discernible wear in the cylinders and the compression was 145-160 across all cylinders. For those who have dealt with this I can now say.....
