- Replies 53
- Views 6.3k
2000Ram2500 26 posts
dripley 15 posts
Mopar1973Man 3 posts
Dieselfuture 2 posts
None of the work you describe is difficult to do. It is all bolt off bolt on and you can find good articles right here to explain it better. I am not mechanic either but have done quite a bit with hel
I would just get a new VP if yours is original something like Industrial Injection. Even if it bench tests ok, I doubt there's much life left in it, especially the ones that came from Factory. Even th
To be honest @Dieselfuture ive wondered the same thing that maybe its just the pumps time to go. Its had a pretty rough last 30k miles. Tons of long cross country trips. San diego to denver and back t
So I'm back.. started the 2 stroke oil. P1689 hasn't been giving me any trouble for a while.
Today while driving to work someone came to a complete stop in the middle of the road so to keep moving I stepped on it to pass and go around them. As soon as i stepped on it I had nothing. It was acting like the p1689 problems i was having but 10x worse.
On my lunch break a minute ago I drive to go pick up cigarettes and it's doing it some more but very minor by comparison. On my way back to work I was barely able to make it up this slight hill and i had little to no power and was blowing blue (oil?) smoke the entire way.
Now to fill in some details, I may have done too much oil in the fuel on my last full up by about 2 or 3 ounces. I tried the edge on stock mode with no change so I just disconnected it but haven't driven it that way yet. In park in my parking spot I was revving it to try and get it to act up so I could hear what is going on and it ran/sounded fine with the exception of a very minor hiccup that I could barely tell was there.
I'm assuming my next step needs to be getting a mechanical gauge and check fuel pressure. But that's where I'm drawing a blank. Not really sure what direction to go with this. I wish I had the ability to data log I feel like that would give me the extra input I need.
