- Replies 11
 - Views 1.4k
								dave110 4 posts
								Mopar1973Man 3 posts
								dripley 2 posts
								01cummins4ever 1 post
Popular Days
http://dodgeram.info/tsb/2000/08-05-00.htm Found...
I had similar situation a few years ago, turned out that it was the main plug in the PDC was loose, I just had to re set it, but be carefull when checking it is easy to over torque. Just got to do it
I have been getting an intermittent no bus message since July or so. It had went away until my hunting trip last week. When it happens I of course lose all my gauges, but I can pick them up on my ScanGage2 through the OBD port. It seemed to happen on rough road so out of curiousity I tapped, or more like punched
 the cluster and everything came back up. This happened a few times. Since I can read speed, tach, etc. through the OBD port when the dash goes blank is it safe to assume that the problem is a loose cluster? Just trying to narrow it down before I start the long drawn out testing process.
