- Replies 17
- Views 5.1k
Marcus2000monster 6 posts
dave110 2 posts
IBMobile 2 posts
Dieselfuture 2 posts
Weld in a stud then use a nut and washer to hold the sway bar bracket in place. The new bolt I see there is not metric but grade 5 standard.
I have in the past welded a wire to a nut and then slid it in a hole in the frame rail and manuvered it to the offending hole and then bolted it back together. If you have an opening even a foot away
Looking under yesterday the suggestion I gave would work pretty well I believe. Might have to enlarge the existing hole a little. If you didn't like that here's another. There's a pretty large hole ab
Not sure if this is actually my fault but upon my steering gear install one of the frame brace/ Sway bar bracket bolts stripped out. Turn out theyre is a nut inside the frame rail that is stripped and spinning out. Now what the heck do I do? I can see know possible way of getting another but in without cutting into the frame and that’s not what I want to do? Any suggestions? I’m worried about the sway bar flying off at some point becuase of only one bolt on the drivers side holding it up.
