No power lots of smoke when cold
- Replies 6
- Views 2.6k
Mopar1973Man 2 posts
Garrisson09 2 posts
Dieselfuture 1 post
Me78569 1 post
I have a 2001 24 valve and it has no power and smokes white like crazy when its cold. It will do this even after sitting for only 2-3 hours if i let it idle for 25 minutes or more it will be fine still some smoke some not alot more in 1st 2nd and a blueish tint but lots power. Not getting a code for vp44. I have the air intake sensor unplugged all the time because when its plugged in then it has no power almost all the time. Once trucks been running for 25-30 minutes it works fine but it will lose power right at 1450-1500 rpm in 3rd 4th 5th if u hold it there for a while, usually happens if i get stuck behind slow traffic and im at that rpm.If i drop a gear to bring the revs up or go through the rpm without stopping at that rpm its fine. Trucks only got 270,000km yes im from canada lol. Any help would be greatly appreciated or if someone has had a simillar issue. Thanks in advance.
