New to quadzilla
So I just ordered a quadzilla iquad and my question is should I start with a daily tune that I can download from here or just make my own? I won't be using the wire tap so do I need to set the wire tap values to 0 or just leave them alone. Thanks for any help. Also got a fass coming too.
  • Replies 84
  • Views 15.8k
  • haha no worries, the beauty of the quad is being info on what works and how things work
  • yep canbus fuel.     Fueling you really can't hurt anything on stock injectors.  you could run %150 of stock from 0 psi to 30 psi and be just fine.  I call it the S03 tune lol   as for
  • sounds good.   I never ran the New tuning on a stock injector truck so I dont have a great grasp on how much fuel you can throw at it .   easy enough to find out, just go WOT from a stop, if you
This morning I started my truck and walked away the high idel tried to kick on and cut right back out. 30 seconds later it done it again. So I just pulled out my phone and cut off the warm up mode. What can cause this?  It was 27° this morning so I know it was cold enough.
So... After you turned off the warm-up mode the high idle did stop correct? I'm just wanting to verify which high idle system is operating. I know the ECM high idle from Cummins will cut out if the engine load is too high during the high idle mode. Like exhaust brake, grid heater load and super cold temperatures can cause Cummins ECM to cut out the high idle. As for the Quadzilla high idle I'm assuming its an APPS fooler but not sure if there is a cancel trigger because of excessive load.
I only have quadzilla high idle for now. When I started my truck I let it run and walked off the high idle kicked up then off after maybe 2 seconds. Then 30 seconds later it kicked up to 900 or 1000 then right back to normal idle. After the second time I got a little worried and just used the app to turn off warm up mode all together. It didn't go into high idle anymore.
mph > 0
tps > 0
brake engage on 98-00
ect > that set temp
Ok now my boost pressure is stuck on 12.. when I press the fuel from a dead stop it acts like it jumps from no tune to tune pretty hard.  This ain't been as nice as I was hoping for so far.  Using default tune 3.
boost stuck on 12 means your map sensor or your map wiring is causing issues.
you are going from 0 psi map at idle to 12 psi map off idle.  thats a large jump in fueling.
What should I replace first? It went back to zero this morning and done fine.
Edited by Unreal Summit
It's possible the MAP sensor failed within spec. In other would just stuck at the 12 PSI value. It won't throw a P0237 or P0238 code because it not out of range. Then it won't trip a P0234 code because it not over boosting. The only one it "Might" trip is the P0236 code because it not changing value and stay high long than it should. The P0236 code will not set a CEL.
I wouldn't replace anything yet.
from 0-16 psi the quadzilla is reading boost from the data sent out from the ecm.  If the quad shows 12 psi all the time then the ecm is seeing 12 psi all the time.
More than likely it is a failing map sensor, but I would wait until it happens again and troubleshoot when you have the issue to make sure you narrow the issue.
It is fairly common for the map to fail like this.  Most never reconize it as most tuners dont show you the issue.
I never really paid attention to it but some days the truck would feel lazy then other days it would be peppy! I'll wait till it does it again or gets worse. Guess oem is the best option to replace with right
I would watch the live data. ECT, IAT and Engine Load. When the IAT falls below +80F then the ECM kicks in extra +4 degrees of timing roughly. Which might be too much timing for cold weather and high cetane fuels. Then when the IAT warm up above the +80F then the timing retards and the performance typically improves. This all can be seen with engine load and cruise control.
I would guess he is right that some days it feels peppy because the ecm jumps right to 12 psi offidle
I'll put those up on my screen today so I can watch um. If that happens can it hurt my truck? That's alot of timing.
I wouldn't worrya about it.  timing spike due to cold weather is not something that happens iwth the quad only stock timing
Doubtful seriously. ISB engines will take quite a bit of timing. The thing is by the time you get to the point of bucking you should have already noticed the engine load is higher because of negative torque. This is why I limit my MAX timing slider to 27 degrees because beyond that point bucking starts. VP44 is capable of 32 degrees of timing. As injectors get larger more timing is needed. I'm going to step up to 7 x 0.010 injectors since my current 7 x 0.0085 have nearly 100k miles already. I'm after efficiency but try to match Nick and get the same number he did.
Alright good!! No bucking or anything like that. I like the power just take a while to get the issues worked out.
What you need to do is get into high gear and get up to 2k on the tach. Then read your timing. A good starting point is 19 to 20 degrees at 2k RPM on flat ground on cruise timing.
You might read over my article on this.
  • 4 weeks later...
I been playing around with my tunes and this morning I noticed at 1500 rpm I had 19 degrees of timing. I was going maybe 15 to 20 mph and climbing a decent hill. Is this to much timing? No bucking or smoke. Just curious.  I got my timing to 18.5 to 19 at 65 to 70
I do have a data log I just got to figure out how to post it if it's needed.. still learning how to use that to tune by
