New to quadzilla
So I just ordered a quadzilla iquad and my question is should I start with a daily tune that I can download from here or just make my own? I won't be using the wire tap so do I need to set the wire tap values to 0 or just leave them alone. Thanks for any help. Also got a fass coming too.
  • Replies 84
  • Views 16.2k
  • haha no worries, the beauty of the quad is being info on what works and how things work
  • yep canbus fuel.     Fueling you really can't hurt anything on stock injectors.  you could run %150 of stock from 0 psi to 30 psi and be just fine.  I call it the S03 tune lol   as for
  • sounds good.   I never ran the New tuning on a stock injector truck so I dont have a great grasp on how much fuel you can throw at it .   easy enough to find out, just go WOT from a stop, if you
post your tune and we can tell you why there is that much timing.
might be a bit much depending on your load.
19° at 1500 RPM is rather high. Typically 19° at 1900 to 2000 RPM. Is more normal.
How old are your injectors?
the tune is what we need.  At least the timing settings and timing per rpm
I attached two pictures of my timing settings.  I will have to look at my engine load at idle. I have no idea how old the injectors are
What is you engine load at idle? What is the idle speed?
Will report later had to leave truck at home this morning
drop 2k to 17* and light throttle to 1.5*
oem timing is used under 120* or 130* or something.
Cold engines need high timing.  Don't worry about timing values until you are up to temp.
Welp I just wasted y'all's time.. sorry guys. I paid really close attention this afternoon coming back home and my timing was at 19 to 20 at idle. Then by the time I got to the end of the road it was 13 to 14.. sorry guys.
Not a waste of time just gotta take some time to learn.
Full temp it should idle at 12°. Always work with a fully warm truck when tuning. 10 to 15 mile drive get it nice and warm.
If I would of thought about it for a few minutes I should of known better to start with. But I freaked out because I been messing with the tune more lately. Timing more so trying to get more mpg. The quad is awesome and let's u keep up with alot all at one time it's nice.
Any downside to running more canbus fueling. More strain on the vp44 or anything? I got it turned up to 121 starting out and still no smoke. Add more or no?
Add more until it smokes on wot take off and lugged passing.
