tranny heat exchanger
- Replies 12
- Views 6.8k
Bullet 4 posts
Dynamic 2 posts
Evan 2 posts
army_greywolf 1 post
Old thread, I know. But I wanted to clear up the fact that the heat exchanger is not there to bring the fluid up to temperature. It is there to cool the extremely hot fluid coming from the torque conv
If coolant temp flowing through the heat exchanger is higher than the ATF flowing through the heat exchanger, then yes, there will be a heating effect on the fluid. But the designed purpose of the hea
My gauge is in the hot line and I see a stable 150 driving around town. 180-185 in traffic...195 is the highest I've seen. These figures are all post heat exchanger removal for compounds.
As i was installing a DPS compound set up on my truck i ran into a problem. The tranny heat exchanger that sits on the driver side of the block is in the way and has to be removed or relocated in order for my big turbo to fit, has anybody removed this or relocated it and how so?! any help is greatly appreciated as i have to figure this out by Friday night!
