Here is the one issue I have since doing my gear swap. I also replaced my WIF drain on the filter canister before this started. Intermittently but frequently upon braking the pedal will get hard and my brakes will do just what they do   When abs kicks in if you try to lock up your brakes on ice. What could have caused this?
  • Replies 30
  • Views 5.4k
    Give the dealer a call and ask them. Another would be ask Chris O about it he should know.
    "The Worlds Greatest Group of Cummins Minds" all in one spot on the internet...    The more you hang around and talk to people you learn so much and there are so many resources at your finge
  • Marcus2000monster
    Marcus2000monster
    I’ll do that. Also I read something about dirt getting in the sensor holes and such? Wouldn’t be surprised if some landed in they’re.  I’m beginning to wonder if ABS stands for Antagonizing Bull
1 minute ago, Dieselfuture said:
Maybe I'll try to warranty one of these new Timken hubs. So much for buying made in usa stuff
I would most likely spend money on a Timken sorry... Just like I would most likely not spend money on Cummins parts either. Like everything I use has either been NAPA or RockAuto supplied parts.
I'm a slow learner, just wanted to support made in USA stuff
My wheel hubs are Timken I hope they work!
Maybe try bleeding your brakes again. Since you had the system opened up maybe there is still some are left in it that somehow is messing with a BS computer
I’m beginning to wonder if ABS stands for Antagonizing Bull Sh$t instead of Antilock Braking System lol
Check the ABS speeds while driving then see if a sensors is dropping during braking. Like my case the right time ring would drop to 0 after slowing 30 MPH. Mine was not the sensor but the unit bearing is bad.
Ok il do that as well. Do you think debris on or in the sensor would cuase this? I sort of remember seeing dust in theyre but didnt think much about it.
Maybe. If there is metal stuck to magnet of the sensor it can foul the magnetic field to the tone ring. As a metal tooth passes it creates an AC pulse. But with grease loaded graphite in the tone ring can do the same problem.
Ok plan of attack for this problem is to bleed brakes, remove and inspect front abs sensors, monitor ABS data...
