Wide open throttle still
- Replies 12
- Views 3.9k
dripley 4 posts
JAG1 4 posts
Mopar1973Man 3 posts
CODYFARLEY 1 post
Popular Days
Sure you aint been smoking the high altitude Oregon logs again? AA HA HAAAAA old friend. Couldn't resist that one.
I would say you have an bad ground somewhere, but then again I've been more wrong than right about such matters. Still a bad ground creates an unbalanced electrical system to where AC noise cannot be
It would not hurt to check the new alt out. Some fail out of the box, more than you might think. Checking grounds and general elctrical health is always a good idea.
So after reading most of the forums i could find im still haveing the wide open throttle issue. I put a new APPS on it calibrated it started the truck up worked great. But if i turn the truck off and start it back up its wide open throttle again when i touch the gas then back to idle when i let off. But i can unhook the battery cable for 20 minutes or so hook it back up start the truck and it works fine. Any help or suggestions would be greatly appreciated, thanks.
