- Replies 12
- Views 5.6k
Stanley 5 posts
Tractorman 3 posts
Haggar 2 posts
Dieselfuture 2 posts
This is what I have, slipped right onto the gear box..
No worries. The required grinding is when a Borgeson steering box is being used with an OEM steering shaft. The grinding is done only on the adapter for the steering box shaft - not on the actual st
A few years ago I installed a Borgeson steering shaft and a Borgeson steering box and no modifications were necessary. From what I recall, if a Borgeson box was installed on an OEM shaft, then a flat
So in my "Dove in Head First" thread I mentioned that I got a Borgeson steering shaft upgrade while i had everything apart. I have read a few time in other places that you need to grind a flat spot on your gear box shaft and that the original flat spot is not used.? Why and why? Got the old one pulled off last night and was looking at how I was gonna fa-naggle this thing in there, but grinding a new spot on top of that - ge wizz...
