AirDog Toggle Switch hardware
- Replies 27
- Views 6.6k
tmropr1991 10 posts
Mopar1973Man 8 posts
dripley 3 posts
hdpwipmonkey 3 posts
Popular Days
The other 2 probably come from ECM and that's what trigger the relay to energize. Don't connect the other 2 anywhere if you're planning on using toggle switch. Sounds like you have more than one
Wait to start not coming on instantly with key on, lift pump not working properly, sometimes surging, random codes all at once, the list can be big. A lot of it is from bad grounds, bad alternator wit
I've been having some problems with my AirDog. So I've decided to hardwire it with a toggle switch. But since it has the relay I don't know which wires go where. I know I can jump the yellow and red together to turn it on but what are the other two. Do I need to tie those into somewhere too?
