4k quadzillas tuning
Hey guys anyone on here have any experience with the 4k's I have the hard fuel tune and I keep messing with it but can't seem to get the spool up like I had before I got the 4k mod done, I don't know if anybody has any tunes I could download all help is appreciated
  • Replies 8
  • Views 2.3k
  • Datalog and post your tune.     The only real difference in the tune is the rpm settings to allow for more timing variables.  You can just match your old tune and set the new timing variable
Great I just didn't know if I could download a tune like standard V2 I just got it modified last month and just got the truck done so I haven't had a chance to play with it
The only real difference in the tune is the rpm settings to allow for more timing variables.  You can just match your old tune and set the new timing variables to 30*
I don't have a tune anymore I had to update my app and start over and I will when I get off of work, before the mod I was running the torq tune because it was v1, I'm new to V2
ok.  Well let us know when you have a tune built and have questions.
  • 4 weeks later...
How evolved is it to build a tune.
With the iquad can you  change tunes right on the tablet or phone.
I'm looking Into the quad and not understanding how you guys are building custom tunes. Do you plug into the windows computer to change setting within settings
Does the iquad tune the same as one that just comes with the pod that allows changes on the fly?
In like how the torq tune says do not contact support regarding this tune.
I'm very interested in the defueiling at 12-1300 deg
Edited by Evan
Download the app and try it yourself.  The functions all work,
the tune on the pod is the base tune, the custom tuning on the iquad allows you to change ~46 of the tuning variables within the base tune.   The base tune is "replaced" when you use custom tuning on the iquad.
If you want to know more look up the tuning guide artles.  It covers what each tuning variable is.
